[DesignModeler] Geometry help
Old   June 24, 2013, 16:29
Default Geometry help
Louisiana
lbrumf2 is on a distinguished road
Hello All,
I am trying to design a simple 2D model. The simulation is to be a heated flat plate to observe buoyancy driven flow. So, the top of the domain is to be fluid with a solid (heated) surface underneath.
The problem is that I am trying to model a micron scale asymmetric structured surface that is basically a repeated asymmetric triangle. So I need the fluid domain to match/mirror the solid surface. I can model the solid, but I cannot seem to get the fluid sketch to work. I am pretty new to FLUENT so please don't overlook a simple solution.
I have also tried doing this in Solidworks. I modeled the fluid and solid domains as separate parts then mate them, but I cannot mate 2D drawings so I extruded them a small amount. When I try to mesh it, the computer freezes.
Please help!
lbrumf2 is offline   Reply With Quote
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
[ANSYS Meshing] need to convert a cell based geometry into STL or CGNS kamran_kibria ANSYS Meshing & Geometry 0 September 15, 2011 05:14
Reg difficulties in meshing the geometry...Urgent arunraj ANSYS Meshing & Geometry 0 August 26, 2011 23:25
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 19:51
[GAMBIT] import terrain geometry cfdworker ANSYS Meshing & Geometry 2 May 24, 2009 21:40
