June 25, 2013, 10:39 |
#21 |
Maxime Perelli
Rep Power: 41 |
3) either you work with pave, or you try to get quad-map
For that you can for instance split your surface like that Untitled.png And then of course you have 9 surfaces as source + the opposite one
In memory of my friend Hervé: CFD engineer & freerider |
June 25, 2013, 10:58 |
#22 | |
Rep Power: 13 |
Ah ok, perfect!!! Now I insert BC, that is: 1)I specify a specific continuum (solid) 2)I specify boundary tipes, that is face with Temperature Ta and face with temperature Tb (as in first post attachment). The face opposite to displayed face has temperature Ta, displayed face and upper face of parallelepid have Tb. Lateral faces don't care. ok? Heat transfer is perpendicular to plate, that is a simple Fourier Equation: q=k/x*A+(Ta-Tb) k by material x by model, it is thickness A is area But fluent don't calculate right flux, it seems that there is no flux. I must insert another BC with this subdivision, maybe on face in common? The 2 volumes are connected... |
June 25, 2013, 11:43 |
#23 |
Rep Power: 13 |
Ok remove all!!
I'm really tired!!! I forgot 1 volume End of problem!!! Thank you very much Max!!!!! :-) |
Display Modes | |
[ANSYS Meshing] Very thin plate (0.1mm) ICEM CFD bad meshing | msormania | ANSYS Meshing & Geometry | 1 | April 30, 2012 07:45 |
[Gmsh] Meshing thin, curved solids in Gmsh | tibich72 | OpenFOAM Meshing & Mesh Conversion | 0 | January 5, 2012 11:05 |
Problem with meshing long, thin faces in CFX | Martin | CFX | 3 | January 8, 2009 20:51 |
thin extrusion meshing | guillaume | CFX | 7 | October 29, 2008 05:39 |
thin extrusion meshing | guillaume | FLOW-3D | 0 | October 27, 2008 18:38 |
