[ICEM] Aircraft unstructured mesh problem on density trailing edge |
July 5, 2013, 08:08 |
Ch
Rep Power: 13 |
Hi friends,
I am doing an unstructured mesh around an aircraft. When I used the density on the trailing edge, I found there were still holes near it. So I continued to decrease the size in density function, then all of the mesh on aircraft body was disappeared. Does anybody know it? How to solve it? Many thanks! |
July 5, 2013, 11:06 |
Adding pictures for the questions
Ch
Rep Power: 13 |
Hi friends,
the first picture is the mesh I used the density bars in ICEM with size of 0.08. The second one which the body mesh disappeared is after I increased the density bar size to 0.05. If you guys know what happens, please let me know. Thanks |
July 5, 2013, 11:29 |
Ghazlani M. Ali
Rep Power: 28 |
did you use the feature "define thin cut" ?? if not, that's what you should use for the trailing edge. do a google search or a forum search for define thin cut. It has been discussed before
July 5, 2013, 11:34 |
Rep Power: 20 |
By which method you are generating the mesh? top down octree or bottom up delaunay?
July 5, 2013, 14:57 |
Ch
Rep Power: 13 |
Thank you very much for such fast response! Yes, now I used the function "define thin cut". And it do work at the begining if I just defined the two parts (upper surface and down surface)for one of two wings. But I have double wings of the aircraft. Once I involved the second wing into the two parts for defining thin cut, the mesh on the aircraft body disappeared again! I was just excited to see the changes, but again the same problem comes. DO you have any idea about it? Thanks again for your help!
July 5, 2013, 15:00 |
Ch
Rep Power: 13 |
Hi, I just keep the default settings, so what I am using is the bottom up delaunay. What's the difference between these two? Does this matter with the problem I mentioned above that the body mesh was diappeared?Thanks for the reminding!
July 5, 2013, 16:57 |
Answer
#7 | ||
Hi mate,
Try using Patch Dependent along with Delaunay algorithm, and maybe you would have no such problems.
ICEM, CFX and Fluent expert |
July 6, 2013, 06:38 |
#8 | ||
But octree method does not require surface mesh at all. So when you use octree you do not need surface mesh at all. Quote:
http://www.cfd-online.com/Forums/ans...rmula-one.html But I am not in favor of this method despite of its Awesome looking mesh. 1. It is slow method and you lose all advantages of ICEM which is famous for its top down approach. 2. You need high quality and well connected geometry which is not required by octree. 3. You need to define size on each and every curve. 4. Density boxes and size functions do not work with patch dependent surface meshing. Tetra meshing is successful, fat and accurate in ICEM (in first attempt) if you can properly define sizes and other options such as thin cut etc. |
July 6, 2013, 11:30 |
#9 |
Rep Power: 20 |
I don't know why but ICEM always have problem in meshing curved leading and trailing edge surfaces of wings
If "Define Thin Cuts" is not solving your problem then I suggest another method. Split the surfaces of wings at some distance from leading edge and trailing edge both. Now you have three surfaces on the suction side and three surfaces on the pressure side. Mesh the two surfaces near leading edge(suction and pressure side) and two surfaces near trailing edge(suction and pressure side) with either Patch Dependent Method or by Autoblock method. Go to Compute Mesh and compute only the surface mesh on these 4 surfaces. Apply other settings on parts and surfaces, densities as normal. Now again go to compute mesh and calculate Volume Mesh by Octree Method by selecting " Use Existing Mesh Parts" . During the process Octree works as normal but in the end replace the mesh on these surfaces with Patch Dependent or Autoblock method. By this way you will have a nice surface mesh adapting to the curvature of the geometry. After this you can replace the volume mesh with Delaunay and insert prisms according to your requirements. I hope I have made myself clear but if you have doubts come back again, I will post a pic about the procedure of the method. |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[GAMBIT] Trailing edge mesh problem | Bharatt | ANSYS Meshing & Geometry | 11 | June 30, 2012 00:57 |
ICEM aircraft mesh trailing edge difficulty | MontyR | ANSYS Meshing & Geometry | 4 | July 23, 2011 21:46 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
