[ICEM] Element Quality.
Old   July 1, 2013, 07:38
Default Element Quality.
Marco Antonio
marcoymarc is on a distinguished road
Hi guys,
i have a newbie dubt. Why element quality is so important for a sim to converge? Which numerical implications exist due to bad aspect ratio ? Thanks in advance
marcoymarc is offline   Reply With Quote
Old   July 1, 2013, 12:39
Default Answer
sadjad.s's Avatar
sadjad
sadjad.s is on a distinguished road
Send a message via Yahoo to sadjad.s
Hi mate,
I classify element quality in two ways:
1- Skewness; which is a criterion about angle of elements. Actually Fluent and almost all CFD commercial codes recommend to have cells with angles more than 18 degrees. With cell angles less than 18, there may be a possibility of production of error in domain which results in divergence.
2- Aspect ratio; ratio of largest side of element to smallest one. Some times having high aspect ratio is no problem, like boundary layers where aspect ratios more than 1000 may be allowed. But Fluent suggest to use "Double Precision" solver for cells with aspect ratio more than 100.
ICEM, CFX and Fluent expert
sadjad.s is offline   Reply With Quote
Old   July 2, 2013, 04:57
Marco Antonio
Yes ok, but what i'd like to know is how bad quality affects numerical stability..
Ty
Old   July 2, 2013, 13:10
Marco Antonio
How a bad aspect ratio is supposed to make a simulation diverge? Googled it all around, and found nothing "technical"; only a few words on good quality improving stability and accuracy, but not about the HOW.
Old   July 2, 2013, 14:12
Default Answer
sadjad.s's Avatar
sadjad
It doesn't make solution diverge in all problems. Actually it depends.
First of all consider that in Control Volume approach, there can be only one value for variables (like velocity, pressure, temperature,...) in each cell.
Let me give an example; In boundary layer, we have no gradient along the wall. In that situation, high aspect ratio cells along the wall are no problem. They won't cause divergence neither.
But consider a high aspect ratio cell in high gradient region. While calculation, solver has to put only one value on that cell, while there may be gradient across that cell. This error (neglecting gradient) can cause divergence.
About skewness, you may have to refer to "Control Volume" and calculation of cell wall fluxes.
Old   May 19, 2014, 06:58
Default mesh quality (orthogonal, skewness, element)
eray
erayerisik is on a distinguished road
hi guys, I am new here and also sorry for my poor english I have checked site before write this here, however I could not find any solution.
I am working on analysing of an airfoil (naca2412). I have doubt with element quality. I had finished my mesh, then opened fluent, it says your orthogonal quality is under 0.01. What does it means? Also is anyone can give me some advice to improve my mesh quality? I attached pics.
Thank you all...
erayerisik is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[ANSYS Meshing] Inflation layer / Element quality Spookz ANSYS Meshing & Geometry 17 February 12, 2019 04:55
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
autoPatch error, mesh quality related...? Alexvader OpenFOAM 0 October 6, 2011 17:57
Tetras, Prims, BL-resolution and element quality fonzie CFX 2 November 30, 2009 03:33
