[ICEM] Avoiding repetition (how to divide the main block to small ones) |
July 4, 2013, 07:27 |
Mfm
Rep Power: 12 |
I am trying to mesh Tube bank using ICEM. After drawing the geometry I wantted to o-grid mesh each cylinders .there are like 130 cylinders (there is no way to take a portion coz the geometry isnt semmetric).The problem is I have to manually divide the main block and then apply the o-grid technique to each cylinder (just like in this video http://www.youtube.com/watch?v=T2Dxa0OZf58). I THINK EXPERTS WOULD NEVER GO THROGHT Rrepetition PROCCESS LIKE THAT).Any cluse to handle this problem.Is there command that divide the main block into small ones based on the curves (cylinders) that are inside the main block.
Thanks in Advance for your help. Last edited by meshoxx; July 4, 2013 at 18:31. |
July 4, 2013, 08:13 |
Javi
Rep Power: 16 |
There is no pattern between cylinders?
Can you share a picture? |
July 4, 2013, 08:22 |
Mfm
Rep Power: 12 |
yes I can !
July 4, 2013, 18:30 |
Mfm
Rep Power: 12 |
I mean that there is no way to take a porion of the physical domain for the CFD.It is a tube bank just like the in-line pattern but the cylinders are Sinusoidally distributed in the stream-wise direction.
I drew one horizontal row then I transformed it vertically. |
July 5, 2013, 05:21 |
Mfm
Rep Power: 12 |
No one can help solving that ?.I need to divide the domain into small blocks covering the cylinders
divide icem block |
Display Modes | |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 04:15 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 11:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 03:58 |
blockMesh: block with 6 vertexes | dani | OpenFOAM | 3 | June 25, 2009 14:13 |
