July 6, 2009, 20:27 |
Workbench non-manifold body
Adam Loesch
Rep Power: 16 |
I am attempting to make a CFD mesh in Workbench. In the DesignModeler, I import my igs surface body and create a primitive prism. When I try to do a Boolean subtract of the surface body from the solid prism, the operation fails with a "Error: Operation would result in non-manifold bodies." What exactly does this mean, and what type of corrective action can/should I implement?
July 7, 2009, 11:39 |
Baffles me.
Simon Pereira
Rep Power: 47 |
DesignModeler does not yet support the subtraction of a surface from a solid (aka, a baffle). This is coming at 12.1 (due out in Q4 2009).
If your surface body was actually supposed to be a closed solid, you will need to sew it into a solid first. Then subtract the solid from the primative solid. If you were trying to have a baffle, you have several options. You could use it to completely chop the primative solid; you will need add some other surfaces to make the segmentation complete and then adjust the contact to block flow only along your baffle… I haven’t actually done that myself, but I heard it was possible. Another option is to extrude the zero thickness wall into a thin wall. You can then subtract this thin solid from the primative solid. This may better reflect your actual model, but the thin edge may raise your mesh count and/or reduce your quality. Simon |
July 3, 2013, 20:05 |
Non-manifold bodies
Waqas
I have made a wind turbine model but in ANSYS design modellor, I am constantly receiving an error message "operation results in non-manifold bodies". Could anyone suggest me a remedial action? Thank you |
bodies, body, non-manifold, workbench |
Display Modes | |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 05:19 |
Body force at the cell face | Souviktor | Fluent UDF and Scheme Programming | 0 | March 31, 2009 09:54 |
Workbench Transient | Omer | CFX | 0 | January 15, 2007 15:21 |
allowable body size in ANSYS Workbench 8.1 | Atit Koonsrisuk | CFX | 1 | January 5, 2005 13:40 |
