-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ICEM] Bottom-Up Block in ICEM (http://www.cfd-online.com/Forums/ansys-meshing/120413-bottom-up-block-icem.html)
cfd seeker July 6, 2013 09:42
Normally in ICEM we start with a large block, make some splits according to geometry, some associations and adjustments etc for hexa meshing. This is what we call as Top-Down approach.
Now my question is it possible in ICEM to start with Bottom-up approach i.e make vertices, join them with edges and then associations and further process at a desired location in the geometry. Is it possible? If yes then what's the procedure?
I don't know but I always like this way of working because often I got confuse in making proper associations after the initial splits.
Can anybody share his/her ideas???
Thanks
Regards
Far July 7, 2013 04:33
Yes it can be done.
But we can not start with vertices or edges. Minimum starting level is 2d blok either from points/location or directly.
For 3d block, you can start from either from 2d blocking (2d to 3d blocking) or from 3d block and extrude it to get the required mesh.
