July 10, 2013, 11:15 |
Vehicle aerodynamics-Flow analysis
Anand
Rep Power: 12 |
Hi everyone...
I've been trying to model the flow around a car with an aim to determine the aerodynamic lift and drag induced and the local velocity near the rear of the vehicle(almost at a point where the leading edge of a spoiler will come) to a fair level of accuracy. I tried to add prism layers around the vehicle body and near the ground...I've attached the screenshot of the settings i gave...plus the rough mesh i got without the prism layers My problem is that am not able to generate the prism layers as ANSYS Meshing seems to freeze after sometime but it doesn't crash I've tried running it for hours but its still frozen ...it seems to get stuck at "Modelling interior for part"... Any reason that anyone might know ?..i don't think its because of my low end system...coz its not using more than 2.5GB of my system memory(I got 8gigs) ! |
July 11, 2013, 02:27 |
Stuart
Rep Power: 25 |
Are you using the pre prism generation, rather than the post prism generation? If so you could then preview the prism mesh (before it makes the volume filling tetrahedral elements). This might help in working towards solving your mesh issue. I cannot recall if this works of the first aspect ratio optio but you ould change to smooth transition or first layer height, for instance.
July 11, 2013, 07:20 |
Rep Power: 14 |
Ansys meshing is super finicky and super buggy. I have loads of problems with it. What version are you using? V 14.5 was supposed to be worlds better but I noticed in 14.5.7 all sorts if bugs and freeze ups. When I have these issues I delete the meshing cell and start from scratch. Then as I'm rebuilding I has controls one at a time and mesh. This helps to find the problem. It wouldn't surprise me if there was a bug in their code that wasn't happy because you has 3 face sizings in a row. I've had a bug caused by something similar.
By the way, why are you modeling the interior? |
July 11, 2013, 12:16 |
#5 | |
Anand
Rep Power: 12 |
And regarding the interior, i was trying to include the volume of fluid between the wheel arch and the tires as well...i guess that's what u meant ? May be that small volume had been creating problems for me |
July 11, 2013, 12:45 |
#6 | |
Constantine
Rep Power: 12 |
Try to exclude the interior of the vehicle from the area calculation |
July 11, 2013, 12:53 |
Anand
Rep Power: 12 |
I tried to include the volume of air between the wheel arch and the tires as i sd. The mesh you see doesn't include the entire wheels. That's how it should be..right ?
July 11, 2013, 13:57 |
Rep Power: 14 |
I think I misunderstood the image you showed. You have a symmetry model and this is a side view, isn't it? I was under the impression you tried to mesh the volume of the interior of the car. My
Mistake. One thing I have noticed is that sometimes inflation can't run ansys meshing into the ground as it appears to have done to you. It looks like you have a very fine mesh around the tires. I bet this is where meshing messes up. Please try placing a coarse mesh on the wheel, and all over, then try. If that works you can reduce the mesh size from there |
July 22, 2013, 06:24 |
#9 |
Anand
Rep Power: 12 |
Thanks everyone for your replies. I had found out the cause of the error. It was a problem with my geometry, where the wheels met the bottom surface. The lowest part of the tires had a very small angle between them and the ground,because of which prism layers could not be generated.The solution adopted for this was cutting the lowest part of the tire using design modeler four millimeters over the surface. Then, the tire was extruded on the Z direction(vertical) connecting the tire and the ground and then the prisms could be generated.
Display Modes | |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Steps for analysis of a flow | rskrishna87 | CFX | 15 | February 1, 2011 11:08 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
how to do this blade passage flow analysis ? | manish | CFX | 2 | January 16, 2006 03:58 |
Coolant flow analysis - IC engine | Frank | FLUENT | 2 | May 19, 2002 15:59 |
