-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] Mixing faces that constitute a velocity inlet boundary condition (http://www.cfd-online.com/Forums/ansys-meshing/120604-mixing-faces-constitute-velocity-inlet-boundary-condition.html)
babakflame July 10, 2013 12:05
Dear Buddies
Hi
I have divided a velocity inlet boundary condition to three faces. There is no problem with the grid. However for crowding out the grid, I want to do an operation like merging these faces so as to observing one circle instead of two half circles and a square in the middle. I had found a solution for this issue; However I have forgot it now. Any hint is appreciated.:)
More information: It's a 3D grid and after creating the 2D surface grid;I swaped through an identified edge to create the 3D grid.
Regards
Bobi
-mAx- July 11, 2013 07:03
I don't understand your problem.
If you have 3 surfaces and they should set as velocity inlet, then you have 2 options:
-all 3 surfaces as one BC --> you will see only one surface
-each surface as one BC --> you will see 3 surfaces
babakflame July 12, 2013 02:31
Hi Max
Let me explain clearer:
when we sweep our faces through a specified edge that has an identified mesh on it; we can create our 3 dimensional grid . After this step, we can see undue lines that sweeping has created in the interior region. My question: Is there any way to get rid of these lines In the interior region? From your response, I infer that after defining boundary conditions properly; these undue lines due to sweeping disappear automatically? Am I right buddy?
Regards
Bobi
-mAx- July 12, 2013 03:26
can you post pictures?
babakflame July 13, 2013 03:07
1 Attachment(s)
Hi max
I have attached a picture. As it can be seen in the picture, After sweeping through the central edge (I have deleted this line); the vertices of the middle square create four lines. Is there any way to get rid of these interior lines.:rolleyes:
Although I Know that these interior lines does not disturb in defining boundary conditions.
Regards
Bobi
-mAx- July 17, 2013 01:32
if all your volumes are well connected, then the internal surfaces won't give you any problem, since Gambit will treat them as interior.
So connect Faces All
