[ICEM] embedded meshing
Old   July 18, 2013, 05:33
Smile embedded meshing
kai
zkzkzk010537 is on a distinguished road
can any one tell me how to perform embedded meshing on 2D geometry? Its like the way that the mesh size increase twice times bigger than previous one. The project is a nozzle inject fuel in to a chamber. i need the mesh size smaller at nozzle.
Thanks
zkzkzk010537 is offline   Reply With Quote
Old   July 18, 2013, 06:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
are you talking about mesh refinment?
Far is offline   Reply With Quote
Old   July 18, 2013, 06:42
kai
yes, refinement, i need the mesh better at nozzle but the size next to previous one have a larger size (twice times bigger)
Old   July 18, 2013, 06:44
Far
Sijal
Your mesh is hexa, If yes then the procedure is :
Blocking > pre mesh parameters > Refinement
Old   July 18, 2013, 07:06
kai
Thanks for your reply but could you please tell me how two operate in refinement as i am totally new in icem. What is the meaning of level here? and does it mean i should select block by block to set meshing dimension? what if i have one big block and i want to have different meshing size in this single block? I really couldnot find a video relevent to meshing with different sizes.
Old   July 18, 2013, 12:24
Far
Sijal
If you want the mesh refinement in specific region, you should isolate it by splitting block. Once you get the required block where you want to use the refinement function follow the images given below. You must keep in mind that Fluent allows 1: 2 refinement and CFX requires 1:3 (let me re-check requirements of each code). You can also resolve refinements in ICEM to avoid problems.
Old   July 18, 2013, 13:21
kai
Thank you very very much!!!!!!!!!!!!!this is exatly what i need!!!!!!!!!!!!!Thank you !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old   July 19, 2013, 05:03
Far
Sijal
Was it helpful?
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
