[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem |
July 19, 2013, 07:04 |
dalecooper
I have been doing some simulations with vertical axis turbines in Fluent. In order to achieve good results I have tried using the Inflation option in Ansys Meshing module around the different airfoils in the turbine. But I found a problem in Fluent that says: 'Divergence detected in AMG solver'. When I disable the Inflation option the problem disappears. I have tried different meshing methods as quadrilaterals and triangles as well as refining the mesh using sphere of influence around every airfoil, but still I haven't found a proper solution to the divergence error. Thanks in advance and best regards. |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
problem with meshing an enclosed airfoil | stacey | FLUENT | 0 | July 7, 2013 05:29 |
Airfoil Meshing | PLP3A_ENSIAME | STAR-CCM+ | 14 | October 10, 2012 18:29 |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 04:36 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
