[ICEM] Octree tetra is created only in restricted area |
July 22, 2013, 07:37 |
Andrew Kang
Rep Power: 12 |
Hi, I'm trying to create simpe tetra grid
but ICEM only creates tetra in the restricted area. I put the result files. http://www.2shared.com/file/YC6A6Y0T...o_problem.html Should you have any idea why this is happening, please let me know.. I'll really appreciate it.. |
July 22, 2013, 10:19 |
Answer
Hi mate,
the problem is within periodic definition.
ICEM, CFX and Fluent expert |
July 22, 2013, 11:02 |
Thanks a lot.
Andrew Kang
Rep Power: 12 |
I also just figured it out
Here's another question, I have a multiple edge from mesh check. Then I found out that if I delete one of nodes of multiple edge-having tetra, then multiple edge problem disappears. Is it ok to just delete the problematic tetra element's node to tackle the multiple edge problem?? If it's not ok, is there a better way to correct these elements? |
Non overlap area fractions | saisanthoshm88 | CFX | 11 | September 17, 2015 18:42 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
