-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [ANSYS Meshing] Creating named selection of interior region (http://www.cfd-online.com/Forums/ansys-meshing/121137-creating-named-selection-interior-region.html)
Thermal_engg July 22, 2013 13:27
Hello everyone,
In my project to simulate a heated rod kept open to atmosphere,I first created a solid cylinder representing the rod and then concentric to it, I created a much bigger solid cylinder representing the domain of fluid flow.After that, using "Boolean" operation, I subtracted the smaller cylinder from the larger one, thereby creating a cavity COMPLETELY INSIDE the big cylinder. Now how do I create the named selection for that interior cavity.
Any help is appreciated.this is rather urgent .Thnx..:)
vasava July 25, 2013 04:17
I suggest you dont name the interior and rather let fluent take care of it. If you name the interior boundaries they may act as 'interior'.
Shamoon Jamshed December 9, 2013 16:05
Named selection of ineterior
I have a surface (wind blade) with multiple faces inside an enclosure, I have already subtracted the faces from enclosure using boolean in ansys mesher. How do I specify names of the wall surfaces of the blade. The box slect option doesnot select all the faces
