December 7, 2012, 10:14 |
Volute
Christoph
Rep Power: 17 |
Hey everyone!
I've done several volute hex meshes in the last month. As I know, how annoying it could be to achieve a reasonable quality, I decided to provide my blocking approach and/or my scrip file to anyone, who's interested So if you become desperate on trying to make a good blocking, just let me know.....I'll help you out |
April 8, 2013, 05:48 |
wadoud
Rep Power: 15 |
please i have a problem with volute meshing, i need a help
April 9, 2013, 06:52 |
volute meshing
wadoud
Rep Power: 15 |
i want generate a hex and tetra meshing withe a good quality
April 13, 2013, 04:54 |
generate a hex and tetra mesh with a good quality
wadoud
Rep Power: 15 |
I have generated a hex mesh of the volute but I have in the area of cut water a problem and for tetra mesh I could not generate a good mesh.
I want to generate a hex grid and another tetra mesh with prism with good quality I want how i can generate a hex and tetra mesh with a good quality. please i need a help. thank |
April 13, 2013, 05:07 |
wadoud
Rep Power: 15 |
April 13, 2013, 14:34 |
nitin bansal
Rep Power: 13 |
CAn you share your tin file
April 17, 2013, 04:45 |
volute meshing
wadoud
Rep Power: 15 |
thank you for helps it
how i can me with hex and tetra with good quality |
April 18, 2013, 04:53 |
volute meshing
#9 |
wadoud
Rep Power: 15 |
thank you for your reply, i will read it
Best Regards |
April 29, 2013, 11:33 |
I wait your help
#10 |
wadoud
Rep Power: 15 |
i have problem to meshing the volute please i need your help
July 14, 2013, 09:59 |
#11 |
wadoud
Rep Power: 15 |
hi
I spent enough time to mesh the volute I used icem cfd (see the picture) but I have a problem of the negative element in the area of cut water. thank you Best Regards |
July 25, 2013, 04:42 |
#12 |
wadoud
Rep Power: 15 |
hello
I used to icem cfx14.5 realized this mesh but I have the message of negative Elements in cfx pre at the area of water cut my question is: how to avoid this problem (the complexity of the geometry) and how to avoid inverted blocks thank you my friends |
July 25, 2013, 10:59 |
#13 |
Ghazlani M. Ali
Rep Power: 28 |
sometimes you can't really do something against the complexity of the geometry, you then have two choices:
Change it in a more simplified one. Or go with the unstructured mesh... it's your call |
July 28, 2013, 06:45 |
#14 |
wadoud
Rep Power: 15 |
hi
thank you my friend for the document, I will try to change the mesh; best regards |
Volute outlet flow into impeller inlet | Anthony_impeller | CFX | 4 | December 13, 2011 16:17 |
I have a two meshes Impeller and volute | tareqkh | FLUENT | 1 | February 18, 2011 01:27 |
Simulation of a single passage and volute | Suzzn | CFX | 1 | January 5, 2010 07:05 |
tascflow - impeller volute interface | abaqus | CFX | 0 | August 21, 2003 13:06 |
volute geometry definition | Derrik Mazzer | CFX | 2 | May 15, 2001 08:20 |
