July 18, 2013, 08:28 |
Can someone help me
Eugen Zec
Rep Power: 12 |
Im new here so im sorry if I did something wrong, and about my question I hope there is some little thing I did wrong and can change it easy.
I'm creating a mesh which ill use in fluentbut at the entrance and exits my mesh goes wild and i dont know how to fix it, can someone pls help me. Im using ogrid and when i use my mesh is good in all places except entrance/exit. skewnees is awful and it looks like this [img=http://imageshack.us/scaled/thumb/28/3y1.png] [img=http://imageshack.us/scaled/thumb/21/wjjj.png] mb this should be moved to ANSYS Meshing & Geometry |
July 18, 2013, 13:48 |
Eugen Zec
Rep Power: 12 |
Hi Far and ty guys for helping me.
https://www.dropbox.com/s/d8w8lnstn5x0tsh/preogrid.zip this is what i have...and pictures you see are what i get after using ogrid. I need agood mesh so i can use it in fluent, i need to learn how to do it. All i know i've learned online so I'm not very good...tyvm |
July 18, 2013, 15:03 |
Eugen Zec
Rep Power: 12 |
If this can help someone, this one of my version after using ogrid, this mesh is also bad, around intersection of pipes...pls help with this :/
https://www.dropbox.com/s/qc05lk52uytb7v8/postogrid.zip |
July 18, 2013, 15:19 |
Eugen Zec
Rep Power: 12 |
I cant, I did all my geometry with CATIA
July 18, 2013, 15:29 |
#9 |
Eugen Zec
Rep Power: 12 |
Yeah, this looks great, can you explain me how did you do it. I'm sorry if im too demanding, i really want to learn how to do it
July 18, 2013, 15:35 |
#11 |
Eugen Zec
Rep Power: 12 |
Well, you've helped me alot, hopefully this will be good enough mesh for me do some calculations in fluent.
THANK YOU AGAIN |
July 18, 2013, 15:46 |
#13 |
Eugen Zec
Rep Power: 12 |
Diamond, can you explain me how did you do that, yours is also awesome, how?
And thank you very much |
July 18, 2013, 16:17 |
#14 | |
July 18, 2013, 16:26 |
#15 |
Ghazlani M. Ali
Rep Power: 28 |
there is nothing better than a video to explain this. but i can't install a mkv codec due to privileges. i will try to do that from home. meanwhile i did the necessary split. and merge some vertex together, and o-grid were the last... look at the tutorial "3d pipe junction" it is same blocking strategy, you can start from that one to understand
