Home > Forums > ANSYS Meshing & Geometry
Boundary layer on Unstructured mesh
Old   August 7, 2013, 00:17
Default Boundary layer on Unstructured mesh
ravi
pendyala is on a distinguished road
Hello All, I have a small question. Could we create a boundary layer on 3d unstrured mesh in gambit. I need to capture flow seperation and since, I cannot have a really fine mesh on my object, I wanted to use BL. This doesn't work. So any suggestions??
Thanks in advance.
pendyala is offline   Reply With Quote
Old   August 7, 2013, 05:57
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
sure you can: http://aerojet.engr.ucdavis.edu/gamb...tm#mesh_blayer
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 7, 2013, 09:53
ravi
The boundary layer is placed inside the body. Like on the surface, but can't it grow above the 3d structure? For ex in the sail boat meshing in gambit tutorial 14. I hope u got my question.
Old   August 7, 2013, 10:34
-mAx-'s Avatar
Maxime Perelli
in 3d the BL has to be attaches to the wall surface
Else post pictures
Old   August 7, 2013, 11:29
ravi
In the picture I uploaded to see the flow desperation I have to refine my mesh and since I cannot mesh so fine due to system limitations I have to have boundary layer. But when Put a boundary layer, I couldn't have it properly.
Old   August 7, 2013, 11:38
-mAx-'s Avatar
Maxime Perelli
display how look your BL like, even if you cannot create it.
Old   August 7, 2013, 11:59
ravi
I am currently out of my workspace. So cannot publish pictures right now. Will do shortly. In the image I updated its the front part of my body. If u observe there is higher space between each cell. So to decrease cell distance I want to lay a BL. How to attach a BL to this surface?? Do we go SELECT BL give the first length. If I do so, the BL grows on the surface of face . But it doesn't grown on top of face( grows exactly the way it is shown in link u posted). My basic is how to reduce the distance between cells without effecting
Old   August 7, 2013, 20:13
ravi
I want boundary layer in the edges in the 1 st block but I'm getting as in the picture..
Old   August 7, 2013, 20:23
ravi
Below image, as u see, in the 5 boxes box like faces available, I want to have BL on each face with spacing .00001 intial length. So, I couldn't ge that though. The while patch is the BL I'm getting. So, any suggesting as to how that works??
Old   August 12, 2013, 00:41
-mAx-'s Avatar
Maxime Perelli
in your picture I don't see any BL attached.
If you do it right, you select the surfaces of your body as attachment, and give first cell's height and also how many layers you want.
Thread Tools
Trackbacks are On
How to set boundary layer of a moving body in ICEM to a mesh zone for dynamic mesh WassimCFD FLUENT 0 July 13, 2013 14:24
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Boundary layer in a pipe Clementhuon OpenFOAM Native Meshers: snappyHexMesh and Others 6 March 12, 2012 13:41
Boundary Layer Mesh in GAMBIT Jane Wilkinson FLUENT 2 December 4, 2006 10:36
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
