[ANSYS Meshing] Defining total thickness for inflation. What is growth rate?
Old   August 13, 2013, 22:00
Default Defining total thickness for inflation. What is growth rate?
pyroknife is on a distinguished road
Is there any way to define the total thickness for the amount of inflation layers you specify?
In local inflation, you have an option called "total thickness," but the name is very misleading since it only allows you to define the "maximum" thickness of the inflation layer rather than the "total" thickness of all inflation layers.
Also, what is growth rate for inflation?
pyroknife is offline   Reply With Quote
Old   August 14, 2013, 10:33
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
there are 4 parameters; initial height, ratio, number of layers and total height.
You can 3 of them and the 4th will be calculated.
Total height is the total thickness when you specify the initial height, a growth ratio and a number of layers...
If you specify the total height, you need to leave one of the other parameters (usually height or ratio) blank so the equation isn't over constrained.
the growth ratio is the ratio of one layers thickness over the layer below it.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   August 14, 2013, 12:31
Under "Inflation Option," I can choose from one of the following:
1) total thickness (which actually defines the maximum thickness of one thickest layer)
2) first layer thickness
3) smooth transition
4) first aspect ratio
5) last aspect ratio
Old   August 14, 2013, 12:36
PSYMN's Avatar
Simon Pereira
Oh, sorry, you are using ANSYS Meshing. I was talking about ICEM CFD. My bad...
Take a quick look at the help for the definitions and for how to setup prism differently.
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Inconsistent Total Heat Transfer Rate Ken Adams FLUENT 0 July 24, 2007 11:04
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
Help! Total heat transfer rate doesn´t sum to zero Thomas FLUENT 0 April 6, 2005 02:55
Total shear rate in a 3 dimensional flow Bo Busk Jensen Main CFD Forum 3 May 23, 2003 15:26
