Home > Forums > ANSYS Meshing & Geometry
[ICEM] Skewed element - Radiused surface -fillet
Old   August 13, 2013, 15:30
Default Skewed element - Radiused surface -fillet
Luca
LM4112 is on a distinguished road
Dear all,
I have some skewed elements because of a fillet. I have attached the CAD model, blocks strategy and mesh result. Have you ever dealt with this kind of problem? Do you think that I have to change my blocks strategy? thank you in advance
best regards
Luca Metelli
LM4112 is offline   Reply With Quote
Old   August 14, 2013, 03:14
Stuart Buckingham
stuart23 will become famous soon enough
I can't think of any way to get around this except for making the block follow around the surface of the diffuser inlet, and then create an unstructured swept block on the adjacent edge of the diffuser wall.
Nothing else springs to mind right now, maybe someone else may have a useful topology.
Stu
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   August 14, 2013, 10:36
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Two thoughts...
1) If your solver doesn't mind prism elements, you could use a collapsed block or a swept block instead of the quarter ogrid block...
2) you could deflect that wedge down into the space below it... Those blocks would get compressed a bit, but it would open up the angle and give your elements more space.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   August 14, 2013, 10:47
Luca
Dear Stuart and Simon,
thanks a lot for your replies. I will try to follow your suggestion and I will let you know.
best regards,
Luca Metelli
Old   August 14, 2013, 13:02
Luca
Originally Posted by PSYMN View Post
Two thoughts...
Dear Simon,
I have tried your second option but I'm not sure if I have understood properly what you mean. The solution that I have tried in shown in the first image attached; this strategy solves the problem on the "blue" plane but not on the side plate (yellow) as I can't deform the edge down in that way without altering the geometry of the model.
Can you please tell me the steps to follow in your first solution? (collapsed or swept) thank you
best regards
Luca
Old   August 14, 2013, 14:36
PSYMN's Avatar
Simon Pereira
Oh, sorry, I didn't realize that ledge was there preventing you from deforming...
The other solution (collapsed block) is just to create a wedge block (with a row of prisms on the sharp end).
How did you create your Y-Block? A collapsed block is easier.
You can merge pairs of verts or create it bottom up from 6 verts...
Old   August 14, 2013, 15:02
Luca
Actually I was trying to have a first row of prisms elements but I don't know how to do that. I think that I know how to create an edge block, the problem is how to generate prisms. Am I supposed to convert it in a free block or swept block? After that how I can create a mesh of prisms elements and merge it with the structured grid? Than you
When I created the blocks I deleted the block under the diffuser and then I created a wedge block manually. After that I just used "create Y-grid".
best regards
Luca
Thread Tools
Trackbacks are On
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
snappyHexMesh aborting Tobi OpenFOAM Native Meshers: snappyHexMesh and Others 0 November 10, 2010 04:23
Highly skewed element. EYITAYOAFOLABI FLUENT 4 July 20, 2009 01:27
Got unknown element in Post after adaption Atit CFX 0 March 2, 2004 07:42
How much does a skewed element effect a solution ? joseph CFX 3 April 8, 2002 00:21
