[ICEM] Etrude face
Like Tree8Likes
  • 1 Post By highhopes
  • 1 Post By diamondx
  • 1 Post By Far
  • 1 Post By Far
  • 1 Post By Far
Old   June 23, 2013, 15:16
Default Etrude face
nabaen is on a distinguished road
How can I extrude the faces block of cylinder to frustum in cyclone?
nabaen is offline   Reply With Quote
Old   June 23, 2013, 15:29
highhopes is on a distinguished road
Hello nabaen,
It seems you have already selected 7 of 9 faces, and clicked "extrude faces" button. After that select "extrude along curve" in the "method" drop down menu. Then select all the 9 faces, and icem cfd will prompt you to select a curve. Then, select that line connecting the red points, which are located at the ends of the frustum. Finally, select the red point located at the narrow end of the frustum and apply. Hope this helps.
nabaen likes this.
highhopes is offline   Reply With Quote
Old   June 24, 2013, 03:12
Originally Posted by highhopes View Post
Hello nabaen,
Thank you so much for your reply.As you said I select 9 faces (you can see at picture) .after that I select the curve that connects two centers and finally I select the the red vertex.But i receive fail warning.
would you please help me?
Old   June 24, 2013, 03:33
this is my ICEM file.would you please chek that it is posibble to extrude the blocks to frustum?https://hotfile.com/dl/230440335/013...clone.rar.html
Old   June 24, 2013, 16:49
Unfortunately, I cannot open the project file. Some attributes might be missing. About the geometry, are you sure the curve you select is cut at the point on the wide side of frustum? If not you can try segmenting it like this
Geometry tab->Create/Modify Curve->segment curve. Then select the curve, then select the point and apply. If you receive the same error message, then try extrude faces->interactive. Select the same faces, move your mouse and associate the edges and vertices to anywhere you want ont the narrow surface of the frustum.
nabaen likes this.
Old   June 24, 2013, 20:30
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
extrude interactively then associate and move vertex
nabaen likes this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 24, 2013, 23:14
Thank you for your reply.
I received same message for interactive extrusion. "Extrusion of faces failed.
Old   June 25, 2013, 05:22
I think I can suggest that you do an extrusion using a simple geometry like a rectangular prism from scratch and maybe you'll notice what is wrong. Or you can simply associate and move the edges and the vertices at the wide surface of the frustum to the other end and go with only slicing the blocks without extruding them.
nabaen likes this.
Old   June 25, 2013, 06:26
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I tried on your geometry and extrude along curve is not working. So i used simple extrude command (fixed distance and it is working)
blocking is also attached. Although some problems are still there, but blocking is complete
nabaen likes this.
Far is offline   Reply With Quote
Old   June 25, 2013, 10:36
Far
Sijal
Ali I have never been able to use "extrude interactively" function. do you know how to do it ?
Old   June 25, 2013, 10:37
diamondx's Avatar
Ghazlani M. Ali
keep pressing on the middle mouse button...
Regards,
Ali
Old   June 26, 2013, 06:18
Far
Sijal
yeah, it works
Old   July 9, 2013, 13:57
Dear all,
I am a beginner in Icem.Please help me for meshing the cyclone.I could make a block for cyclone using your advice.as you can see in the picture.Now I have problem for making mesh.when I mark "pre-mesh" a few line only appears in geometry.would you please advise me for steps of meshing?
Old   August 19, 2013, 10:51
I have been involved with this cyclone a long time.
Some bad meshes are in the inlet as you can see in the attached picture.
So I tried to use your blocking strategy for this part.But it doesn't work.Would you please help me to improve this part.
Thanks a lot.
Old   August 19, 2013, 11:00
Far
Sijal
i dont think you can get rid of this problem without doing any one of the following:
1. change geometry or
2. use unstructured mesh in that region
nabaen likes this.
Old   August 19, 2013, 11:04
Thanks a lot.
But your mesh is better than mine.
How is it possible to use unstructured mesh in this part?
Then output to fluent will be different ?Should I use multi block?
Old   August 19, 2013, 11:13
Far
Sijal
You have to make the tetra and hexa meshes and merge them.
nabaen likes this.
Old   August 19, 2013, 11:56
diamondx's Avatar
Ghazlani M. Ali
My signature will bring you to a small documentation you can read about how to merge tetra and hexa if you ever decide to do that.
There is also this interesting youtube video on how to mesh a cyclone http://www.youtube.com/watch?v=KabKFrJK3fM
nabaen likes this.
Regards,
Ali
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
