[Workbench] ICEM CFD integration w/ workbench
Old   August 20, 2013, 02:31
Default ICEM CFD integration w/ workbench
blaze92 is on a distinguished road
Relatively new to ANSYS, i've been using ICEM CFD to mesh a STL geometry and gained a good idea of how to do it.
I have my workflow set up as ICEM CFD -> Finite element modeler -> static structural to do my analysis. Is there any way to use ICEM CFD in a different workflow method with static structural? Or would it be better to use ansys meshing instead (I find it difficult to import the STL geometry into design modeler).
I want to be able to set up parameters so I can batch process/automate a few models with different BC/loads.
blaze92 is offline   Reply With Quote
Old   August 27, 2013, 03:22
Kind of worked out a solution, thought i would post here incase anyone else has troubles.
I imported the STL model into ICEM CFD, edit -> facets to mesh. Using this mesh I created a volume mesh (to create a solid body, otherwise the geometry only create surfaces). From there I saved the mesh (.uns) and imported that into FE modeller into workbench. From there you can link it to static structural by using skin compontents, creating initial geometry and convert to parasolid (which failed for my STL model of an aorta).
Link the FE system to static structural either through geometry (parasolid) or model (mesh). I was able to open the model in static structural, delete the mesh and remesh it using ansys meshing. Now I can set up parameters and solve quite quickly
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 15:34
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
icem cfd ai environment 11.0, laptop keyboard problem, linux pertupd Hardware 3 October 3, 2011 08:27
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
