spartacurse |
September 16, 2013 04:09 |
Originally Posted by -mAx-
(Post 451914)
Clearly a connectivity problem
try to connect edges (/All)
If it is not successfull , then you will need to split the "long" edge from bottom domain with each "small" edge from channels (one by on), and after again a connect /all
yeah it was a connectivity problem. I managed to solve it using the latter solution. thanks again.
