[GAMBIT] error about volume splitting
Like Tree1Likes
  • 1 Post By -mAx-
Old   September 14, 2013, 05:14
Default error about volume splitting
Tony
l14766 is on a distinguished road
Hi, everyone,
I've tried to use a virtual face to split a volume into two portions, but I always got the following message:
ERROR: Attempted to split volume volume.1 using face v_face.25 that doesn't divide it into two parts (has edges not common with the volume)
Does anybody know what happend? Thanks
l14766 is offline   Reply With Quote
Old   September 16, 2013, 00:56
-mAx-'s Avatar
Maxime Perelli
you are trying to split a volume with a plane (or surface).
If it works with REAL entities, it won't with VIRTUAL.
So in your case, you need to split the edges with vertices. then split surface with previous vertices --> gambit will generate edges.
Finally create the surface you will need to split your volume (pick previous generated edges with wirefram), and split....
Hope I was clear
ayad likes this.
Old   September 17, 2013, 04:36
Tony
Hope I was clear
Thanks, very clear. By saying "create the surface you will need to split your volume", did you mean that I should create a real surface? I have already tried real surface to split the volume, but then it caused problems with the interface, I am just wondering whether it will be better, if I use a virtual surface to split the voume.
Old   September 17, 2013, 04:45
-mAx-'s Avatar
Maxime Perelli
no, you need to create a virtual surface based on the virtual edges you generated (with splits)
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Problem of simulating of small droplet with radius of 2mm liguifan OpenFOAM Running, Solving & CFD 5 June 3, 2014 02:53
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
