[ANSYS Meshing] 3D Inflation mesh on an airfoil |
April 26, 2017, 03:04 |
Ken
Rep Power: 10 |
Hi there!
I used ANSYS mesher to create a mesh for the control volume occupied by the airfoil. I have a problem with the inflation layer on the airfoil surface. Initially, the inflation layers at the tip of the airfoil has high skewness. So I solved it by creating a plane and cut the 3D airfoil at the sharp edge, then further extending the inflation layers at the sharp edge to the wake region of the airfoil. Hence, the inflation layers do not high skewness at the sharp edge. However, by cutting the airfoil into two halves and creating an inflation layer in the wake region of the tail, the inflation layer at the head of the airfoil now has high skewness. So anyone has any advice on how to solve this high skewness at the edge? Or better solution to create inflation layers across the airfoil of good quality? Thank you! |
April 26, 2017, 03:12 |
Ken
Rep Power: 10 |
This is a screenshot of my mesh when I create inflation layers at the airfoil surface ONLY
This is a screenshot of my mesh after I extended the inflation layers into the wake region of the airfoil. (Purpose of this extension is to reduce the skewness of the meshes at the tail) Last edited by kennyboy; April 26, 2017 at 22:07. |
ansys, boundary layer, inflation later, mesh, mesher |
Display Modes | |
[ANSYS Meshing] Problem with Inflation Descreasing Mesh Quality | wildan | ANSYS Meshing & Geometry | 20 | March 4, 2019 03:29 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
