[GAMBIT] Error in exporting mesh
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   September 30, 2013, 13:18
Default Error in exporting mesh
Bobby
babakflame is on a distinguished road
Dear Buddies
I have created a wedge-typed mesh in gambit. Now I want to export it into fluent . Whenever I try to export it; this error comes:
No entities were found for mesh export.
Errors were found during export. Export file was not created.
I have attached a pic of my grid.
Would somebody PLZ help me what is the problem?
Regards
babakflame is offline   Reply With Quote
Old   October 1, 2013, 00:50
-mAx-'s Avatar
Maxime Perelli
Do you have volume elements? (When I see the color of your mesh I would say yes)
Did you receive any error while meshing?
Do you have any BC? (export should work also if you didn't set any BC)
Old   October 1, 2013, 05:19
Bobby
Hi Maxime
1- I swept my faces with their mesh along a specified edge and then deleted the edge.
2- No error appeared during mesh generation.
3- Yes. Maybe its because of my BC. I set periodic boundary for upper and lower surfaces of the wedge. These faces in OpenFoam adopt front and back wedges that are empty (Cause as you might know this wedge is a cut from a cylinder). However I don't know what type in Gambit should I define.
Regards
Bobi
Old   October 1, 2013, 05:33
-mAx-'s Avatar
Maxime Perelli
OF apart, try to delete the periodic BC, and export the mesh.
Periodic BC needs linked mesh
6863523 likes this.
Old   October 2, 2013, 01:28
Bobby
Hi Maxime
Thanks for your hint. However, Would you PLZ hint me instead of periodic BC, what kind should I assign for upper and lower surfaces which in OF they are empty wedges. Because For instance if I assign them wall, it affects the solution or If I consider them outlet; I think it's unreal cause its a cut from a real cylinder and these surfaces are not outlet. So I am a bit confused what type of BC should I assign for them?
Regards
Bobi
Old   October 3, 2013, 01:42
-mAx-'s Avatar
Maxime Perelli
as I said, previously to solve the BC issue in OF, try to solve the problem from mesh export.
Did you now succeed to export the mesh properly (without periodic BC)?
Old   October 3, 2013, 02:06
Bobby
Hi Maxime
It was as you said, I deleted the Periodic BCs and now successfully exported the mesh. However, Now the upper and lower surfaces have no BC. Do you have any hint for me in this step? I mean let them to be as they are (no BC) or anything else?
Regards
Bobi
Old   October 3, 2013, 03:32
-mAx-'s Avatar
Maxime Perelli
ok it means the problem comes from periodicity.
And as I said, periodicity in Gambit has one rule: both surfaces have to be mesh linked.
So delete your volume mesh, link both surface meshes, adn remesh volume
https://www.sharcnet.ca/Software/Gam...mesh_face_link
Then apply BC and export mesh
babakflame likes this.
Old   October 3, 2013, 05:52
Bobby
Hi Maxime
I will try as you said; thanks for your quick reply and also the link.
Regards
Bobi
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Gambit error in exporting mesh in 3D modeling Mazyar FLUENT 5 March 31, 2004 10:50
