Home > Forums > ANSYS Meshing & Geometry
[ICEM] two different part meshing eorror
Old   October 2, 2013, 05:54
Smile two different part meshing eorror
Ho-Hsien Wang
imamwfgf is on a distinguished road
I generated two square blocks sticking together in solidworks with conbine results unchecked.
Then, I import the geometry to icem and it shows two parts for each bock.
When I mesh with Hexa-dominant, it shows
E08 SurfMeshHexAF: intersecting constraints found
Application is finished.
Error: couldn't generate proper mesh
After, I can only get the shell mesh not the volume mesh.
Can anyone help me with this situation?
It was meant for a more complicated geometry, but it seems the problem is due to not combining the results and the two part mesh.
Thanks a lot.
imamwfgf is offline   Reply With Quote
Old   October 2, 2013, 14:37
AhmadReza
ahmadreza is on a distinguished road
Hi
You must make two block for two Part
Did u make ?
ahmadreza is offline   Reply With Quote
Old   October 2, 2013, 23:09
Ho-Hsien Wang
Well, I skipped the blocking process.
I just set the max size in mesh, then run compute mesh choosing hexa-dominant and click apply. And it started meshing.
Old   October 3, 2013, 13:22
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Just as a test, switch to tetra/octree and compute... Does that work?
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 7, 2013, 06:07
Ho-Hsien Wang
Well, it'll generate volume mesh. But shows error when trying to read mesh in fluent,
And the goal is to use hexa-dominant. So, I guess that won't work. Thanks for replying anyway!
Old   October 7, 2013, 08:32
PSYMN's Avatar
Simon Pereira
You give up easily. The fact that it works for tetra tells me that you do have a closed volume. The Fluent error message can probably be over come.
Hexa dominant is not good for Fluent anyway, it is designed for use with ANSYS Mechanical.
So I guess what you mean is you want a hexahedral mesh. How about hexa core or converting the octree to hexa or using ICEM CFD Hexa (blocking)...
Or you could switch to ANSYS Meshing and use the cutcell meshing (assembly meshing)...
Old   October 14, 2013, 05:53
Ho-Hsien Wang
Thank you very much! I'll try them both!
generate propper mesh, two parts mesh
Thread Tools
Trackbacks are On
[ANSYS Meshing] Meshing a t-pipe in Ansys Meshing Kirjain ANSYS Meshing & Geometry 6 August 15, 2012 02:03
[ICEM] Meshing one body part only serezhkin ANSYS Meshing & Geometry 3 June 29, 2010 15:36
Meshing of very complicated part Sanjay Jain FLUENT 9 April 7, 2009 00:21
meshing hollow part of pipe rai FLUENT 0 December 19, 2005 01:46
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
