Home > Forums > ANSYS Meshing & Geometry
[DesignModeler] 3D geometry => slice edges only?
Old   October 5, 2013, 01:50
Default 3D geometry => slice edges only?
François Grégoire
macfly is on a distinguished road
Once a 3D geometry is drawn, can we slice only the edges? Let's say I have a cube, I would like to slice it in half, but I don't want to obtain two parts (volumes), I just want to slice the edges in half, in order to obtain construction points on the parallel edges.
macfly is offline   Reply With Quote
Old   October 7, 2013, 04:22
Smile
vidyanand
Vidyanand Kesti is on a distinguished road
In design modeller please find (next to file,create )option-concept in GUI - Split edges option
Vidyanand Kesti is offline   Reply With Quote
Old   October 7, 2013, 07:57
François Grégoire
I know about Split Edges, it's not a fast way to work, split locations have to be clicked one by one, then adjust split coordinates... It's very cumbersome if, e.g., there is hundreds of edges that you want to split at a given height.
It would be nice if we could create a 'Split Edges Plane' that would split all the edges that it crosses.
Old   June 24, 2015, 03:28
floriank is on a distinguished road
is there any possibility to split edges as described above?
floriank is offline   Reply With Quote
Old   June 25, 2015, 20:14
Kapi is on a distinguished road
Hi floriank,
Try and use Concept>Split Edges and under "Definition" choose "By Split Location" and select and multiple edges which you want to split.
You can change Fraction as well if you need for these edges.
Hope it helps
Cheers
KAPI
Kapi is offline   Reply With Quote
Thread Tools
Trackbacks are On
[DesignModeler] Problem with geometry (Cannot merge edges together) natur3 ANSYS Meshing & Geometry 1 March 20, 2015 07:26
[ICEM] Locked node numbers on edges are changed by ICEM bl!nk ANSYS Meshing & Geometry 0 March 5, 2013 08:56
[DesignModeler] problem with import geometry from catia pavilion ANSYS Meshing & Geometry 1 November 23, 2012 11:45
[ICEM] simplify STL geometry and export it to COMSOL CRT ANSYS Meshing & Geometry 2 November 13, 2012 09:19
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
