Problem in Edge meshing
2 Attachment(s)
Hello guys
I am trying to mesh a converging channel with a slender obstacle inside it. (as you can see in the attachment) My problem is with the edges which have been numbered in the pictures. What I want to do is merging edges 1 and 5 and make the merged edge parallel with edges 2 and 3. Currently edges 4 and 5 are following each other and I can not set the node number on them independently. thanks in advance regards |
I have figured it out.
It was the matter of merging vertices. best wishes |
