Merge or copy of geometries from different files
Hi guys,
I have two complex geometry on the Design Modeler in spearate files. Is it possible to merge the two files or to copy one of the geometries to the other file ? Regards, Efty |
Its possible in DM by reading different files, as well you can export required geometry, by suppressing unwanted bodies
merge two design modeler files
Hi!
I have the same problem! (ANSYS 2019 R3) Does anybody has a solution? I have two files (both are shell models with assigned thickness) And I want to merge them. I tried the answer from Kesti without sucess (how can I read multiple DM files?) Greetings, Holger |
