[ICEM] Mesh elements conflict geometry's surface
Like Tree1Likes
  • 1 Post By kad
Old   October 28, 2013, 08:48
Default Mesh elements conflict geometry's surface
Ali Khalifesoltani
asoltoon is on a distinguished road
Hi to everybody,
I am trying to make an structured mesh around a wind turbine blade(in the fluid domain). But the problem is that the mesh elements near the blade's surface cross it and comes in the solid domain and this is undesirable. I have attached 2 images of my problem. I would be thankful if anybody can help me on this.
Regards.
Ali.S
asoltoon is offline   Reply With Quote
Old   October 28, 2013, 13:42
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Have you checked if all the associations of the blocking to the geometry are correct?
cesarcg is offline   Reply With Quote
Old   October 29, 2013, 03:21
Ali Khalifesoltani
I have checked it twice but I'll check it again,
thanks for the reply
Old   October 29, 2013, 21:53
Cesar
Check for the association of faces to surfaces. I've had similar a problem to yours and found out that the association was taken in a wrong way by the default setting of ICEM.
Regards.
Old   October 29, 2013, 23:01
kad
kad will become famous soon enoughkad will become famous soon enough
Like cesarcg said it looks like an associaton error. It could help to add a few splits in z-direction especially in area of high curvature and associate edges to geometry there. Hexa might not work properly if your blocking does not represent the geometry good enough in these areas, even when associations are displayed correctly. Also run check blocks and fix inverted.
cesarcg likes this.
kad is offline   Reply With Quote
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 2 April 20, 2023 09:28
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 18:29
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 09:06
