Home > Forums > ANSYS Meshing & Geometry
[ICEM] Mesh elements conflict geometry's surface
Like Tree1Likes
  • 1 Post By kad
Old   October 28, 2013, 08:48
Default Mesh elements conflict geometry's surface
Ali Khalifesoltani
asoltoon is on a distinguished road
Hi to everybody,
I am trying to make an structured mesh around a wind turbine blade(in the fluid domain). But the problem is that the mesh elements near the blade's surface cross it and comes in the solid domain and this is undesirable. I have attached 2 images of my problem. I would be thankful if anybody can help me on this.
Regards.
Ali.S
asoltoon is offline   Reply With Quote
Old   October 28, 2013, 13:42
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Have you checked if all the associations of the blocking to the geometry are correct?
cesarcg is offline   Reply With Quote
Old   October 29, 2013, 03:21
Ali Khalifesoltani
I have checked it twice but I'll check it again,
thanks for the reply
Old   October 29, 2013, 21:53
Cesar
Check for the association of faces to surfaces. I've had similar a problem to yours and found out that the association was taken in a wrong way by the default setting of ICEM.
Regards.
Old   October 29, 2013, 23:01
kad
kad will become famous soon enoughkad will become famous soon enough
Like cesarcg said it looks like an associaton error. It could help to add a few splits in z-direction especially in area of high curvature and associate edges to geometry there. Hexa might not work properly if your blocking does not represent the geometry good enough in these areas, even when associations are displayed correctly. Also run check blocks and fix inverted.
cesarcg likes this.
kad is offline   Reply With Quote
Thread Tools
Trackbacks are On
SnappyHexMesh for internal Flow vishwa OpenFOAM Native Meshers: snappyHexMesh and Others 23 August 6, 2014 03:50
[ICEM] Surface mesh not sticking to surface holtwong ANSYS Meshing & Geometry 0 April 4, 2012 06:14
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 14 August 16, 2011 11:20
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
