-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   [GAMBIT] 3D Model Meshing Issues (http://www.cfd-online.com/Forums/ansys-meshing/125829-3d-model-meshing-issues.html)
spartacurse November 1, 2013 03:57
1 Attachment(s)
hi.
i intend to mesh a 3d coldplate with fins, along with 6 thermocouples drilled at each side.
the mesh size of each slot should be around 0.1mm as the diameter of the slot is around 1.6mm.
how can i mesh the slots with a size of 0.1 but mesh the rest of the model at a larger size?
-mAx- November 4, 2013 02:36
with the use of size function: https://www.sharcnet.ca/Software/Gam...ide/mg0502.htm
