[GAMBIT] 3D Model Meshing Issues
Old   November 1, 2013, 02:57
Default 3D Model Meshing Issues
Ikhsan
spartacurse is on a distinguished road
hi.
i intend to mesh a 3d coldplate with fins, along with 6 thermocouples drilled at each side.
the mesh size of each slot should be around 0.1mm as the diameter of the slot is around 1.6mm.
how can i mesh the slots with a size of 0.1 but mesh the rest of the model at a larger size?
spartacurse is offline   Reply With Quote
Old   November 4, 2013, 01:36
-mAx-'s Avatar
Maxime Perelli
with the use of size function: https://www.sharcnet.ca/Software/Gam...ide/mg0502.htm
Compressible turbulence model issues 351Cleveland OpenFOAM 5 October 24, 2013 15:41
[ANSYS Meshing] ANSYS Meshing hangs at "Preparing to model boundary for part" jonny_b ANSYS Meshing & Geometry 12 June 12, 2012 01:55
ICEM: Projectile Meshing and Modelling Issues gman89 ANSYS 0 May 11, 2011 23:01
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
