[ICEM] building goemetry from mesh
Old   November 4, 2013, 09:31
Default building goemetry from mesh
gaurav
guru bisht is on a distinguished road
hi,
i want the goemtry from a given fluent mesh file.
guru bisht is offline   Reply With Quote
Old   November 5, 2013, 11:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
I remember this has been discussed before for sure. I don't remember the steps but I'm sure this was discussed before, use the search tool in the forum or google . Good luck
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 13, 2013, 02:35
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Export surf mesh from ICEM as an STL. STLs can be read by all good CAD software (including ICEM). If you want to Premesh it in ICEM, you will have to wrap it (Octree), but you must realise that if your density is finer than the original mesh, then you are effectively oversampling the mesh, and you may get strange looking surfaces
stuart23 is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
