Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] 2D rectangular cylinder using cutcell
Old   November 7, 2013, 11:26
Default 2D rectangular cylinder using cutcell
Sindre
sindre is on a distinguished road
Hi all,
I'm trying to make a 2d mesh of a rectangular cylinder. I've been trying to create a mesh that is fine close to the boundary. I've therefore tried to use cutcell, but I have met some problems:
I got an error message using cutcell for a 2D geometry, but works fine for 3D (used extrude in DesignModeller). Which is ok as long as I only have one cell in the z-direction. Does anyone know how to fix the number of cells in one direction?
Is there a way to get the fine mesh only around the cylinder (not the outer edges/faces)?
Feel free to add own suggestions/thoughts
Much appreciated
Sindre
sindre is offline   Reply With Quote
Old   November 8, 2013, 03:55
vidyanand
Vidyanand Kesti is on a distinguished road
activate the inflation layer in meshing option or assign the body sizing
Vidyanand Kesti is offline   Reply With Quote
Old   November 8, 2013, 05:16
Sindre
Hi Vidyanand,
Thank you for a quick response
I have been trying to assign edge/face sizing. My logic says that I can remove the elements in z-direction by adding a face size and choose an element size equal to the depth. And that I can use edge sizing to remove the small cells along the outer boundary in the XY-plane. So far without any luck. I'll try using inflation and keep try to use sizing
Old   November 11, 2013, 09:53
Sindre
I finally managed to get a fine mesh around the cylinder using CutCell I made a box in desingmodeler (Create > Primitives > Box) and then defined the fluid around using Enclosure (Tools > Enclosure) and then used CutCell on Proximity - Faces.
My only problem now is to make it 2D (or to only have one element in the z-direction). The help file states that:
The CutCell method uses a patch independent volume meshing approach (surface mesh automatically created from boundary of volume mesh) [...]
Does anyone know how to create/get the surface mesh?
Thread Tools
Trackbacks are On
Flow over a rectangular cylinder CD too low lee557 FLUENT 0 March 2, 2011 14:55
Incompressible flow past a 2D rectangular cylinder Niru Main CFD Forum 5 February 8, 2011 05:20
Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
Cd values for 3D rectangular cylinder karthik FLUENT 1 August 28, 2009 06:32
Drag coefficient for 3D rectangular cylinder karthik Main CFD Forum 3 September 29, 2005 14:18
