[ANSYS Meshing] Creating named selection of interior region |
July 22, 2013, 13:27 |
Prateek Anand
Rep Power: 13 |
Hello everyone,
In my project to simulate a heated rod kept open to atmosphere,I first created a solid cylinder representing the rod and then concentric to it, I created a much bigger solid cylinder representing the domain of fluid flow.After that, using "Boolean" operation, I subtracted the smaller cylinder from the larger one, thereby creating a cavity COMPLETELY INSIDE the big cylinder. Now how do I create the named selection for that interior cavity. Any help is appreciated.this is rather urgent .Thnx.. |
July 25, 2013, 04:17 |
Paritosh Vasava
Rep Power: 22 |
I suggest you dont name the interior and rather let fluent take care of it. If you name the interior boundaries they may act as 'interior'.
December 9, 2013, 15:05 |
Named selection of ineterior
I have a surface (wind blade) with multiple faces inside an enclosure, I have already subtracted the faces from enclosure using boolean in ansys mesher. How do I specify names of the wall surfaces of the blade. The box slect option doesnot select all the faces
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
[ANSYS Meshing] Creating named selections in ANSYS | ejayalv123 | ANSYS Meshing & Geometry | 3 | March 18, 2018 10:14 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Creating named selection for a line sketch | amir00251 | ANSYS | 6 | July 31, 2012 08:02 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
