[ICEM] Translation of ground plane with provided mesh |
December 15, 2013, 08:24 |
Jack Chilvers
Rep Power: 12 |
Dear all,
I have been provided with a structured hex H-mesh for a high-downforce aerofoil placed in proximity to the ground (which is of course the lower edge of the mesh domain). I am attempting to investigate the effect of altering the vertical distance between the aerofoil and the ground. My question is; using ICEM, which approach can be used to easily translate the aerofoil vertically relative to the ground plane? Thank you for reading and I look forward to any response. Apologies if any details have been omitted, please ask if you need any further information. JC |
icem, mesh, translation |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
The mesh file exporter failed during translation. | foolboy007 | ANSYS | 0 | November 2, 2012 14:54 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[ICEM] Growing prism mesh without volume mesh and with a symmetry plane | adenlan | ANSYS Meshing & Geometry | 0 | June 14, 2011 03:53 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
