-   ANSYS Meshing & Geometry (http://www.cfd-online.com/Forums/ansys-meshing/)
-   -   meshing complex 3-D geometry (http://www.cfd-online.com/Forums/ansys-meshing/128136-meshing-complex-3-d-geometry.html)
M-ISMAIEL January 4, 2014 13:58
1 Attachment(s)
dears i'm modeling a 3d model as per attached layout
I've to generate a boundary around the surface walls but i'm not able to mesh the vol that i receive errors
-mAx- January 6, 2014 01:51
You are trying to mesh your volume with cooper, but the volume isn't suitable for cooper.
If you need cooper mesh, then you need to split this volume.
Display only the volume you want to mesh to see how you could split it
M-ISMAIEL January 6, 2014 19:41
thank you for interest
no shem is working.
when i meshed the case without bl it was successfully generated
but now i can't.
i tried to use submab.. mab.. pav but no workinng. if it is possible can i send the file to u
-mAx- January 7, 2014 02:01
Then you have a problem with boundary layer
yes you can provide me your dbs file
M-ISMAIEL January 11, 2014 14:37
Sending the dbs file
1 Attachment(s)
Dear max
please find attached the dbs file
- i've performed wall bl.
If i didn't mesh the edges first, the generated bl spacing will be random from surface to another, accordingly i had to mesh the edges then perform bl. Does edges meshing cause interruption during volume meshing?
I need your advice to mesh the volumes correctly.
- please highlight my mistakes.
The geometry is a segment of an air ring used for blown film cooling.
I've neglected the inlet port volume and just kept the inlet surface to minimize the meshing.
To guarantee similarity around the inlet port, i've divided the inlet circle to 4 quarters and a square.
Thank you for help.
-mAx- January 13, 2014 02:07
I cannot extract the dbs file from your zip
M-ISMAIEL January 14, 2014 00:38
Dear Max
Is it possible to send me your email
To be able to send you the file without compression. The attachment limit in the forum is small
M-ISMAIEL January 15, 2014 15:46
Hi max
Where r u
Hopefully every thing is fine
I am waiting for your email
-mAx- January 20, 2014 02:05
ok I have your dbs file.
On which volume is your problem?
M-ISMAIEL January 21, 2014 00:54
Hi Max
As you see i have a problem with meshing the bigger one.
Usually i start with the inlet port . I deleted it's volume and kept the inlet port circular surface to minimize the meshing elements number.
Then mesh the big section.
And move forward to the exit.
Now i can't mesh the big one. After performing the bl
If you have any different opinion i'd be thankfull.
Performing adequate bl through walls is mandatory. I wish you can try to do this yourself to discover my mistakes and advice.
Thanks
-mAx- January 21, 2014 02:35
2 Attachment(s)
the problem may come from the corner (red marked)
create new BL and disable continuity option
Attachment 28123
Attachment 28124
M-ISMAIEL January 29, 2014 16:12
Dear Max
Thank u i did it and meshed the volume.
Thank you for your time.
During meshing one of the sections
I received a message that no 3d boundary layer generated from surface xxxx
But the gambit generated the mesh.
I understand that gambit generated the mesh but not exactly the same as the b l
Is it correct.
Regards
Hopefully we will be friends
