[GAMBIT] what's the difference between {split volume} {subtract(boolean)} in gambit |
January 8, 2014, 04:36 |
yu. yuxuan
Rep Power: 12 |
I am the newer of gambit, and I do the exercise according to http://cfd.mae.wvu.edu/mae433/PDFs/F...20exercise.pdf
In the first place, it makes the outer_cylinder splitted by the inner_cylinder. But in my experience, I always do that using Boolean cooperation. what's the difference? Thanks. |
January 8, 2014, 05:06 |
Maxime Perelli
Rep Power: 41 |
there is no difference, BUT boolean operations only work on real volumes.
If your geometry becomes virtual after some merge or clean operations, then you cannot use Boolean operations. But you can still use split operations (more difficult with virtual than real, but it works). I only use boolean operations (substrat) for extracting fluid domain from CAD.
In memory of my friend Hervé: CFD engineer & freerider |
January 8, 2014, 05:29 |
#3 | |
yu. yuxuan
Rep Power: 12 |
and Many thanks for your quick response. |
boolean, gambit, split |
[GAMBIT] Need help in meshing volume with Cooper mesh scheme in GAMBIT | Dinesh_Dhande | ANSYS Meshing & Geometry | 0 | June 3, 2012 05:37 |
[GAMBIT] Gambit - Problem having shadow wall on volume | ejvikings | ANSYS Meshing & Geometry | 3 | March 23, 2012 01:30 |
Meshing Volume in Gambit for a water turbine | Zaqie | FLUENT | 1 | July 24, 2009 01:25 |
Gambit: Volume Meshing | fluentnoob | ANSYS Meshing & Geometry | 4 | May 20, 2009 05:21 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
