Home > Forums > ANSYS Meshing & Geometry
[ICEM] Mesh Size (Curve/Edge Bunching)
Old   January 9, 2014, 05:47
Default Mesh Size (Curve/Edge Bunching)
Lilly is on a distinguished road
Dear all,
I am stuck on a problem at the moment:
I got a geometry of some vessel bifurcations where the vessel branches have different dimensions (see pic).
I thought it might be better not to get a too large aspect ratio and therefore shorten the elements in flow direction within the smaller vessels.
Therfore, I tried different things:
  • I tried the "match edge spacing" (my thought was that I could choose the spacing of the first block of an vessel and the following would be adjusted) (but sometimes I get the error message : Warning: edge ... and ... don't match) and also updated the "curve->edge bunching", but this didn't work
  • I tried to set the curve mesh setup for the centerline curves within the vessels and updated the meshing parameters, but this didn't work as well
  • I tried to create a new part of the blocks of one vessel and updated the meshing parameters, but this didn't work too
Does anybody have an idea how I could solve this problem?
Thank you in advance!
Lilly
Lilly is offline   Reply With Quote
Old   January 10, 2014, 13:49
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Have your tried sp1 linked ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/NEbygB
Ali
diamondx is offline   Reply With Quote
Thread Tools
Trackbacks are On
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
unstructure mesh size control near to wall using gambit lalit kumar FLUENT 4 July 6, 2010 15:13
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
