August 28, 2012, 10:27 |
Automatic meshing in Tgrid
Hy everybody,
I use a simple journal to create a mesh, but every time I change a value (number of prism layers for instance), I can't use my journal anymore because of the "automatic naming" of the software (prism-cap-n, interior-n, ..., n is a zone number assigned by Tgrid). Is there a simple way to automaticly rename these prism-cap-n, interior-n, ..., in a journal/scheme ? I'm quite sure not to be the first to ask this question, but I can't find any answer on this forum... Thank you, Neix. |
September 2, 2012, 21:07 |
Stuart Buckingham
Rep Power: 25 |
Hi Neix,
I usually put the following line in my journal scripts after every command which creates a new part. /mesh/manage/name fluid* inner_domain This one I put after tet/init; tet/refine. This way the zone gets renamed from fluid* after it is created to inner_domain. If you are working with multiple domains etc. Put this line after every function that creates a new zone, but specify something that does not begin with fluid_____. Therefore it will not try to rename something you have already renamed. Stu PS. Good to see a fellow TGrid user. Everyone else is missing out on the most efficient tet generation! |
September 2, 2012, 22:14 |
Stuart Buckingham
Rep Power: 25 |
Thankyou Far, however AM is the only software that I do not use. For the same amount of time and effort, I can create a better mesh using ICEM and TGrid.
Having said that, I do think that AM still has a purpose as a reliable mesher for people who just want a hassle free mesh. I'm sure not everyone has the time to spend hours upon hours learning the ins and outs of ICEM & TGrid Stu |
September 3, 2012, 04:35 |
Automatic meshing in Tgrid - resolved
Hey Stuart23,
When I said "a simple way", I didn't think of such a simple one ! I can't believe I didn't think of tring this... Thank you very much, it works ! Just talking about Icem give me a headache. Using Tgrid is not so complicate if you don't try to optimize the grid generation, and change the parameters, and I must say the tutorials are very useful to learn how to use the software. Have a good day, Neix, a fellow Tgrid user. |
January 13, 2014, 07:52 |
Hi Every one
I have to write a code for smoothing iterations in TGrid by using the for loop. (cx-gui-do cx-activate-item "MenuBar*ToolsSubMenu*Auto Node Move...") (cx-gui-do cx-set-list-selections "Auto Node Move*Frame2*DropDownList1(Cell Zones)" '( 1)) (cx-gui-do cx-activate-item "Auto Node Move*Frame2*DropDownList1(Cell Zones)") I hope that you people can understand this scheme program. Now I m facing the problem to change the number "1" (Second line of code Drop down list ) to 2,3 and so on using For loop in Scheme language. I have more than 5 cells zones in mesh. I hope you can help me in this regard. Thanks Kiran |
automatic naming, prism-cap, tgrid |
[ICEM] Automatic meshing | acoustica | ANSYS Meshing & Geometry | 1 | January 11, 2011 11:20 |
using Tgrid meshing from gambit with FIdap | philippe | FLUENT | 0 | September 30, 2008 03:50 |
meshing a wing with tgrid | sandeep varma | FLUENT | 2 | April 16, 2007 03:38 |
Tgrid meshing around cylinders in GAMBIT | Chris | FLUENT | 3 | March 5, 2003 07:43 |
TGRID & Meshing | Eric | FLUENT | 3 | February 13, 2002 10:52 |
