[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh
Like Tree1Likes
  • 1 Post By yona
Old   January 13, 2014, 09:35
Default Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh
Yonatan Afework Tesfahunegn
yona is on a distinguished road
I have imported a Plot3D mesh file into ICEM, that contains WING and Farfield. However the wing tip is not covered by a surface. My interest is to create a surface at the tip and generate mesh. After that I want to extrude all the quad elements from the wing tip plane.
I have followed the the steps as in this thread Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM. I managed to generate the mesh that I want as it is shown in the attached figures.
Before I do the extrusion I wanted to check whether the wing tip surface is recognized by ICEM during writing output to fluent. Unfortunately,ICEM just skipping the wing tip elements, i.e the newly created quad elements at the wing tip. It says, Skipping part WINGTIP (not referenced by grid).
How can I resolve this problem?
Thanks for your help.
Yona
yona is offline   Reply With Quote
Old   January 13, 2014, 10:21
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
have you assigned a boundary for it in the output panel ?
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 13, 2014, 10:33
Hi Ali,
Yes I did.
Old   January 13, 2014, 12:45
Far
Sijal
did you associate the part to blocking?
Old   January 13, 2014, 13:43
Hi Far,
I did not use blocking.
After I import the plot3d mesh, I created curves and surface at the tip of using the Edit/Mesh->Facets tool. After that I generate the mesh using the surface mesh tools by respecting the line elements at the tip of the wing.
Old   January 15, 2014, 13:36
Far
Sijal
if icem is creating mesh why it is not showing part in mesh...
Old   January 21, 2014, 09:05
Default Solution
Finally I am able to resolve my problem.
Rather than simply writing the wing tip surface elements to output, what I did was extruding this part together with other elements that are on the wing tip plane. This time ICEM did not skip any of the elements in the mesh.
I want to thank you those of you who tried to help.
Yona
Old   January 21, 2014, 09:21
Far
Sijal
can you please show some of the snapshots of initial case and final mesh you got!!!
Old   January 21, 2014, 10:06
Here are some snap shots: In the attachment you can ind the initial mesh before extrusion and final mesh after extrusion (Note that some elements are deleted for the purpose of illustration)
Far likes this.
Structured or unstructured meshing of a STL file (surface) Milad06 Pointwise & Gridgen 4 April 25, 2013 11:55
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
3D wing + wind tunnel hexa structured meshing icemaniac178 ANSYS Meshing & Geometry 9 October 28, 2010 09:37
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
