[DesignModeler] export geometry data to turbogrid |
January 21, 2014, 05:47 |
lauda
Rep Power: 12 |
Hello there,
I've read few discussions about how to import an IGES, Step, .. file in Turbogrid. Here there is a useful guide I think: https://www.sharcnet.ca/Software/Flu...tg_output.html however it didn't work for me. I have a single radial blade that I'd like to export to TG from Design Modeler but I'm not sure if it's possible. I go to ExportPoints in the toolbar. The in the details table I select: Export type > turbogrid. Export to file > No. Blade info from Blade. Then I select the surfaces according to the short tutorial in the link I've pasted above. Apply. When I try to generate I get this error message: Error: Failed to generate because of invalid property/properties Context: ansFClientBMExportPts::Execute ExportPoints5 If you had already faced and solved this problem or you know what could be the source of this message please let me know. Thanks. Also, I know that another way (or necessary way?) is to create a flow path first. So I've generated the inlet, outlet and periodic surfaces of the domain. when I try to generate the flowpath I can't select (and apply) any contours (hub, shroud, inlet outlet). Are the contour mean to be surfaces or meanlines? Sorry for the long message. Thanks for you help |
January 21, 2014, 12:45 |
mihai
Rep Power: 12 |
You need to create curves in sketches (in ZX plane) for input, output, hub and shroud. Not surfaces.
October 15, 2014, 07:07 |
Moe
Any news here?
June 14, 2018, 02:39 |
#4 | |
S Satish Kumar
Try to have the export file name short and not in to deep directories. Hope it works. |
Export data in text file | Eferal | FLUENT | 5 | April 13, 2018 10:33 |
extract and export data for each time step | thomasbl | STAR-CCM+ | 12 | August 2, 2017 06:57 |
how to export every data w.r.t time to txt file | jaho | CFX | 94 | August 25, 2015 09:45 |
Export simulation data to 3d mesh | dlugi | OpenFOAM | 0 | May 19, 2011 04:47 |
How to export data | Nareerat | FLUENT | 1 | April 8, 2004 05:26 |
