[ANSYS Meshing] wind turbine simulation meshing problem
Old   January 26, 2014, 13:06
Unhappy wind turbine simulation meshing problem
Max
maxwell94 is on a distinguished road
Hi
i'm currently doing a school project on simulating 3D wind turbine using SRF
method.
I was meshing with sizing with inflation around my wind turbine blade surface.
I try to reduce my sizing "min size" in order to get more accurate geometry shape of wind turbine in mesh, but always getting the error of surface cannot be meshed...
The picture attached below show the cross sectional view of current mesh i successfully build and warning message whenever i try to reduce mesh size.
it would be a great help if you could solve my problem
thank you...
maxwell94 is offline   Reply With Quote
mesh, mesh problem, min size, wind turbine
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 05:27
How to run a wind turbine blade simulation gerritgroot SU2 6 February 8, 2019 14:44
wind turbine simulation otubaba FLUENT 6 April 26, 2013 05:02
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 02:12
