[ANSYS Meshing] wind turbine simulation meshing problem |
January 26, 2014, 13:06 |
Max
Hi
i'm currently doing a school project on simulating 3D wind turbine using SRF method. I was meshing with sizing with inflation around my wind turbine blade surface. I try to reduce my sizing "min size" in order to get more accurate geometry shape of wind turbine in mesh, but always getting the error of surface cannot be meshed... The picture attached below show the cross sectional view of current mesh i successfully build and warning message whenever i try to reduce mesh size. it would be a great help if you could solve my problem thank you... |
mesh, mesh problem, min size, wind turbine |
Problem with torque output from a turbine simulation. | pa-dundas | FLUENT | 5 | July 17, 2022 05:27 |
How to run a wind turbine blade simulation | gerritgroot | SU2 | 6 | February 8, 2019 14:44 |
wind turbine simulation | otubaba | FLUENT | 6 | April 26, 2013 05:02 |
shaft power versus RMP curve in wind turbine simulation | zhenduan306 | CFX | 28 | November 8, 2012 10:11 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 02:12 |
