[TurboGrid] question on bladegen-data import wizard |
January 30, 2014, 08:49 |
lauda
Rep Power: 12 |
Hi there,
I'm trying to import an IGS radial turbine geometry in turbogrid. Searching on the web I found that a good way would be to use data import wizard in bladegen. The process guides the user to select the hub and shroud curves and blade object. I follow the steps until I reach step3 (Edit/Confirm Meridional). I check hub and shroud curves (not only in the meridional plane) and it looks fine so I believe there's need to edit. However I can't proceed to step 4 (blade geometry) since I can't "confirm". I'm not sure what I do wrong, if anyone could help I would appreciate, thanks |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 04:46 |
Import validation data to CFX Post | Vattenkraft | CFX | 0 | November 26, 2009 19:55 |
Problem of import fluent data to ilight fieldview | seasoul | FLUENT | 3 | September 9, 2008 22:36 |
radial turbine data export question | ally | CFX | 0 | September 14, 2005 15:10 |
I-DEAS CAD data import with boundary conditions | Yunus | Siemens | 1 | June 1, 2001 10:04 |
