[ICEM] Blade Leading Edge
Old   January 29, 2014, 16:16
Default Blade Leading Edge
diego flores
drdr18 is on a distinguished road
Hi Everyone,
I'm working on the meshing of a blade compressor (stator). I'm using the C-Grid strategy. However I have issues to associate the mesh to the Leading Edge surface. I did the association with edges and this kind of association inflates the mesh and there is no association with the real geometry. How can I fix the association?
Thanks in advance
drdr18 is offline   Reply With Quote
Old   February 2, 2014, 14:15
Hazem
mezah is on a distinguished road
Send a message via Skype™ to mezah
Sorry this picture is not enough, would you kindly attach more pictures? , or if you can share the files.
mezah is offline   Reply With Quote
Old   February 4, 2014, 04:53
diego flores
Hi Mezah, thanks for asking.
Here I upload some extra images. IN the First one I show a part of the leading edge of the blade. In the next one I show you how the mesh is distort when I mesh with Faces Projection, although the mesh follow the leading edge geometry the distortion is evident. In the third one I show you how the mesh follow the geometry with face projection but in fourth image I change to Edges Projection and the distortion dissapear but there is an inflation and the mesh does not follow the Leading Edge geometry.
I attached the geometry files:
http://www.file-upload.net/download-...ject2.blk.html
http://www.file-upload.net/download-...ject2.prj.html
http://www.file-upload.net/download-...ject2.tin.html
Thanks in advance
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Ansys CFX Turbogrid, Problem with blade leading edge sitting on hub at inlet Irondome CFX 9 August 18, 2016 18:56
Unusual turning angle ahead of blade leading edge carnage2121 Main CFD Forum 0 May 20, 2013 19:11
Y-Plus values at aerofoil leading edge and trailing edge at high incidence Engr07 Main CFD Forum 4 June 29, 2012 10:42
