November 9, 2015, 09:21 |
Splitting Blocks
Florian
Hey guys,
i have some problems with splitting blocks. The picture below shows the blocking till now. The red an the green lines are parallel to each other. I am triing to insert a blocking which looks like the blue lines. So how can i Block this without starting from the beginning. Thanks for any help |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
[ICEM] Splitting blocks without affecting node distribution | Crank-Shaft | ANSYS Meshing & Geometry | 1 | June 20, 2014 09:36 |
[ICEM] Automatic linear interpolation of parameters when splitting blocks | Ivan | ANSYS Meshing & Geometry | 0 | August 14, 2012 07:30 |
