icem meshing + cfx solver
friends ,
i have a wing body geometry which i have meshed in ICEM-CFD - unstructured mesh with a prism layer having y+ as unity i have done two cases , (a) with tetra size ratio (tsr) = 1.25 (in the Part Mesh Setup) (b) with tetra size ratio = 0 i am using CFX solver and solving for Angle of attack 18deg, what i notice is the following : Mesh of case (a) shows the wing stalling at the root Mesh of case (b) shows the wing stalling at the tip i am confused now ..which one is correct ? which Mesh is showing the true physical picture od flow over the wing ? whether to give 'tsr' or not ? Please share your experience on this Thanks Sandeeo |
@Far : sorry i forgot to mention that i am using the Octree Mesh for both cases
i am studying the effect of 'tetra size ratio' on the cfd solution , so this is the only parameter that i am changing in to generate case (b) Mesh from case (a) Mesh also what i have observed is that at AOA = 14 , 16 deg , 'tsr' is not having much effect with flow pattern over the wing more of less same , and separating over the root region..it is only at AOA = 18deg. that the change comes as i have mentioned in my first post. as per your answer , what i understand is that i should not trust the solution which mesh with tsr = 1.25 gives untill i do a mesh independence - or in other words you;re suggeting that i try with tsr 1.3 or say 1.5 and then see ? |
Octree will only grow with the ratio of 2. So if you set it 0 or 1.5 it does not make any difference.
"Octree will only grow with the ratio of 2. So if you set it 0 or 1.5 it does not make any difference"
mesh with tsr = 1.25 has 6.5 Million nodes mesh with tsr = 0 has 5.1 Million nodes and also the way cell growth happens is quite different specially in the vicinity of the body - which i have visually observed by taking a section plane. so i think 'tsr' does make a difference in the mesh. |
1 Attachment(s)
yes you are correct it is making difference but in octree way...
Here is what I just got from TSR 1.2, 1.5 and 2 (0 is same as 2) For TSR = 0 and 2 No of elements 33346 No of nodes 5837 For TSR = 1.5 No of elements 66457 and no of nodes 11409 For TSR = 1.2 No of elements 234322 and no of nodes 39710 http://www.cfd-online.com/Forums/att...tetrasizes.jpg PS:- Geometry dimensions are: Inner cube of size 1 and outer cube of size 10 Mesh sizes : Inner cube : 0.1, Outer cube : 2. Maximum seed size = 2 |
@Far : thanks for the effort you've made for this small research into tsr :)
i am now inspired to do something like this for 'built topology/tolerance' concept and the part sizing to be given..what i have observed is that for built topo with a topo tolerance 1 mm , i am still not able to mesh the flap of the wing (this one being a little more complicated geometry) which shows 'hole' in the geometry thought all the curves have turned red shall update soon on any progress/ problem i face Thanks |
there are many reasons for the hole problem. Recently i have defined two material points : Fluid and Solid . Solid was not closed on one side and even was not required as output mesh. But ICEM was giving error "hole in mesh"
You may give smaller value for the topo-tolerance. By default it is 1/2500 of diagonal of box around your geometry or domain. Please use these documents as reference (By Simon): http://www.cfd-online.com/Forums/ans...efinement.html |
