[GAMBIT] 3D Concentric and Eccentric Annuli
Old   February 24, 2014, 23:48
Question 3D Concentric and Eccentric Annuli
CR-7
Heat Pipe is on a distinguished road
Hi All.
I'm working on 3D Concentric and Eccentric Annuli With and WithOut Inner Shaft Rotation, But so new of this field, So I need a help to draw this geometry by following the correct way as I did my drawing but got warning that the skew is High .
Any help will be appreciated
Heat Pipe is offline   Reply With Quote
Old   February 25, 2014, 01:24
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
display what you did and also display where are skewed elements
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
FLuent simulation of taylor couette flow of concentric cylinder geometry. rshbhb FLUENT 53 November 5, 2014 19:07
Problem with Eccentric pipe annulus..Pls Help me Parag Ramteke FLUENT 2 April 4, 2005 06:34
