March 4, 2014, 08:21 |
Volume orientation error
Edoardo
Rep Power: 12 |
I have just fineshed meshing a stator flow passage, and when checking the mesh it shows there is a volume orientation error in some cells. I used a cut plane to see the corresponding cells and i found out they looks like collapsed. How can i fix this problem? is it possible to do it without modifing the blocking? Thanks in advance |
March 4, 2014, 11:52 |
#3 | |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
